-   Porsche & BMW Parts For Sale/Wanted (https://dorkiphus.net/porsche/forumdisplay.php?f=43)
-   -   WTB Two 6-point racing harnesses with camlock (https://dorkiphus.net/porsche/showthread.php?t=39423)
nikkoman 01-16-2019 12:21 PM
Hello,
I'm in the market for two harnesses suitable for HPDE.
Ideally they would be 6-point, camlock style and if it has the T bar for more room that would be nice :)
I'd like to keep it under $100 per harness if I could.
Thanks!
Nick
HoodPin 01-16-2019 01:34 PM
Why not put the money into some newly dated affordable harnesses, that will be usable for the next 3-5 years. If anyone sells you something used, it may be expiring soon, in which case you'll be looking to buy some more soon.
This link takes you to OG racing's selection between $100 and $200. And if you're local to DC area can probably arrive to your house in 1 day, and should be free shipping if over $100.
Also, I believe PCA no longer allows harness bars for harnesses, so you'll need to have a roll bar. Additionally, if you're using a harness, you'll also need a HANS device. ;)
Dandelion 01-16-2019 02:59 PM
Hi Tony,
I believe that after some discussion last year that there is actually no prohibition on Harness Bars right now.
For the OP - OG Racing has a few option available in your price range. Don't forget that you need a HANS device of some sort w/ Harnesses if you run with PCA.
arob 01-16-2019 03:03 PM
Please do what you can to increase your budget a bit to purchase new harnesses. Spending a little bit more will get you NEW harnesses that will last you much longer.
Chopper Dropper 01-16-2019 03:10 PM
Originally Posted by Dandelion (Post 616908)
Hi Tony,
Depending on the type of Harness bar. The "harness guide bar" as used in a few Targas are not sufficient. I believe Brey Krause has a "Truss" bar that might be OK. Check with BT. Also as mentioned harnesses are only good for 5 years and HANS required, also recommended to have a roll bar with race seats and harnesses though not required.
Dirk
nikkoman 01-16-2019 03:59 PM
Thanks for the suggestions, I must have missed those harnesses on OGs website. I have a rollbar, HANS, and am getting seats from OG. Just needed the harnesses to complete the system.
Patrick3000 01-16-2019 07:23 PM
I may have a used one for a “G” body 911 in the basement, if you are looking let me know and I’ll dig it out.
Patrick3000 01-16-2019 07:26 PM
^^^Never mind just saw this.
Vicegrip 01-16-2019 08:06 PM
Dirk
I might venture a guess that the bar is referring to the old school H style shoulder harness.
