Transient Vibration
On my 996 Race Car I have been chasing a vibration/shaking issue to no avail. The vibration comes on only between ~85-95mph then goes away. It started about a year ago but i cant correlate it to any changes in the car and it has not gotten any worse over the year. From the drivers seat it feels like its coming from the body of the car - not the wheels as the steering wheel isnt shaking.
- problem occurs at these speeds regardless of gas/brake/coast - braking is smooth without shudder and replacing rotors had no impact - problem occurs regardless of which wheels I have on the car - all four wheel bearing have been replaced this year - all suspension parts are tight and i dont see any worn bushings. Ideas? |
You could try putting a dial indicator on each wheel hub. Maybe you have one that is slightly bent.
You appear to have eliminated almost everything with your testing - good job. I'm going to say axle(s). They appear to be the only thing spinning that would only appear at a specific speed (as opposed to Engine RPM). Coming from the car (and not your hands) would further indicate the rear of the car.
Otherwise I will go with Pucker Flutter :) |
axle was my guess also...had a similar problem on a van once though at lower speed....
Check all the plastic under trays and fasteners. Check the 1/2 shafts. Check all the motor and trans mounts for both bolt tightness and condition of the rubber/ isolation system.
Don't go below 95 mph...
<Hagar voice on > “I Can’t drive....... 95!”
| All times are GMT -4. The time now is 02:00 PM. |
