FS: Porsche 968 6-speed LSD Manual Transmission
Good used Porsche 968 6-speed LSD Manual Transmission. Cam from a '93 968 with 95000 miles.
$3400 PM or e-mail if interested. Thanks! https://uploads.tapatalk-cdn.com/201...b305451980.jpg https://uploads.tapatalk-cdn.com/201...97ebf5005c.jpg https://uploads.tapatalk-cdn.com/201...46e468eaf7.jpg https://uploads.tapatalk-cdn.com/201...5258780dce.jpg |
The transmission was opened and inspected. The differential carrier bearings were replaced as well as the output shaft seals and input shaft seal as a preventative maintenance.
Sent from my Pixel XL using Tapatalk |
Would you expect the 968 trans to be stronger(handle more HP) than the 951 transmissions?? Was considering a LS swap in a 968 chassis and want to put the strongest trans I can find in it. Can you install some form of cooler on the 968 trans as a simple add-on or is there internal pump requirement not found on this trans like the 951 with factory cooler?
Thanks John |
Yes and yes.
| All times are GMT -4. The time now is 11:56 PM. |
