new Idler arms and old carrera tensioners leave gap?
I filled my tensioners (pressure fed) last night in an oil vat. I just finished putting them on and I notice that there is a gap between the tensioner and the idler arm. I have the new updated idler arms installed. The gap looks like it's beckoning for a spacer washer. Since I upgraded the idler arms did I forget a couple of washers?
The old spacers are too thick of course. Is the gap supposed to be there? Lee |
Did you get any responses? A picture would surely help me understand.
Lee:
There is a required spacer (thinner - as flange on idler arm is thicker) for the updated tensioner / idler arm. A picture and explanation is in Wayne's engine rebuilding book. If I had it here I'd scan and send but, I don't. The updated idler arm has has a thicker (wider) bearing support necessitating the wider flange. This throws everything else off but ...helps with binding issues thought to eventually cause tensioner failure. Here is a link to the P-parts page for the chain sprocket spacers Jase |
I got a CD with Waynes book.
With a little instruction I could post the picture you are talking about. I think you resolved the question but this would be very helpful for the future. I tried to put it in the gallery but it won't accept the file type. "HTM"? |
Thanks for the responses,
I got a reply back from Wayne in that he says that 1 to 2mm of space is normal. I also called Zims to have them look at their parts diagrams for the 84-on models and there are no spacers, shims or washers of any kind on the idler arm shaft. I sealed the motor up after this. I poured over Wayne's book for a spacer and the only one was for the pre '84 idler arms. I looked at his parts list and found none listed for 84-on. I could probably fabricate one out of the old spacers. I have perfect chain sproket parallelisim. That being, on 456 cyls. the piston of the tensioner going against the idler arm is not 100% underneath the seating area. If the Idler arm were pushed out, the chain would be binding and not running parallel. So I'm running with it. I just assumed that the assembly floats on the shaft with whatever the cam and intermediate shaft is doing. Thanks, Lee[/img] |
OK, I found the pic on Waynes site.
Click on the link above to the cataloge. Click on the link there for the article. It is shown on one of the pictures. I think #6 but just go look. |
Thanks
Lee |
Jase |
No sweat amigo. :D
| All times are GMT -4. The time now is 03:00 AM. |
