| Dimi 944 |
10-05-2017 09:43 PM |
FS: Complete Running 3.0L 16V NA Engine (944 S2)
Complete, running 3.0L 16V NA engine from '90 944 S2.
The engine runs smoothly across the RPM range. It has good oil pressure and no knocks. It comes with everything needed to be installed in Non-S2 944 model: long block, intake manifold w/TB, AFM, air box, fuel rail w/FRP, damper atnd fuel injectors, throttle cable, DME, engine wiring harness, injector resistors, ignition module, distributor cap, ignition cables, flywheel, bell housing w/sensors.
Compression test results available upon request.
$3500 plus shipping
PM or email for more details.
Thanks!
