-   -   Ted's broken stud (https://dorkiphus.net/porsche/showthread.php?t=3764)
914guy 01-17-2004 06:36 PM
Ted's broken stud
Here is the pelican link...
http://forums.pelicanparts.com/showt...hreadid=144395
Marc A 01-17-2004 10:25 PM
Eric . . . Ted needs to get a die and put treads on the stud as far down as he can and then use the collet type stud remover. The snap on version is prone to breaking studs if you can't support the stud to counter the torque. Doug has my die set. I had to do the same thing with one of his studs that broke.
jbailey930 01-18-2004 08:44 PM
I can help with a die set if you are still struggling. Also, I have mapp torch to help. The hotter the better. You can probably convince a local shop to use it O2 on it if need be. Let me know how you want to go.
