-   -   Need advice for "Tach Bounce"? (https://dorkiphus.net/porsche/showthread.php?t=37556)
racer 05-03-2017 06:21 PM
I noticed last weekend that the tach in my 914-6 was acting up. After a bit of driving, it would jump around in the 3-5k range. Usually while accelerating, it would stop moving at 3K, then jump to 4-5k, then fall back to 3k. I recall someone telling me decades ago that "tach bounce" was usually the result of failing or bad points.
I hope to poke around this weekend. I was going to start with checking grounds (related or not, my fuel gauge is a little bouncy too) first - coil, battery, then maybe grounds on the back of the tach?
I also need to go through records. It could be now a couple thousand miles since the last time the car had points checked/gapped.
Otherwise, the engine runs nice and smooth. No hiccups or issues in running through the rev range, just the tach not working quite right.
Car is stock 914-6. 2.0L motor. Marelli Distributor.
Thoughts?
VaSteve 05-03-2017 07:06 PM
That happened to me. I had an MSD unit go bad. Sent it to MSD and they fixed it.
Vicegrip 05-03-2017 07:28 PM
Alternator/regulator issues can cause tach issues too.
