-   -   Whahappunned?! (https://dorkiphus.net/porsche/showthread.php?t=36455)
eltren 07-08-2016 11:05 AM
Whahappunned?!
987 electrics went whacko for a couple days, one window going down to the convertible stage, engine management way off, idiot lights.
Now perfect.
Not wet inside or out!
Seen this?
PinkieLift 07-08-2016 11:15 AM
My 986 electrics went whacko for months (flickering engine temp, abs, low coolant, brake wear) and there was this weird salad dressing smell and it was the alternator.
joep 07-08-2016 12:17 PM
I've had similar squirreliness when the boxster ignition switch was failing. idk your car is alot newer but maybe ??
Dandelion 07-08-2016 01:27 PM
Dying battery...
Vicegrip 07-08-2016 02:07 PM
Asked the Porsche techs and they said low voltage can cause all kinds of odd actions and lights. Battery, bad alt bad connection bad switch and the like.
Lupin..the..3rd 07-08-2016 02:39 PM
x3 on voltage too low due to battery, alt, whatever. Had the same electrics are going crazy experience on my old 996, and it turned out to be low system voltage due to a failing alternator. Replacing the alternator made all the electrons happy again.
Mocker 07-08-2016 04:02 PM
Could also be just a bad/loose ground strap (hey, I'm an optimist!).
Dandelion 07-08-2016 04:14 PM
Originally Posted by PinkieLift (Post 559968)
... there was this weird salad dressing smell and it was the alternator.
Just curious...what kind of salads do you order?
BlackTalon 07-08-2016 05:53 PM
I'm betting salade nicoise
PinkieLift 07-09-2016 11:44 AM
My point was that it was not an electrical smell. It smelled vaguely of olive oil...which made me think it was maybe power steering fluid (which would taste gross on a salad).
