-   -   Suspension Upgrades (https://dorkiphus.net/porsche/showthread.php?t=3603)
thomschoon 11-09-2003 11:50 PM
Suspension Upgrades
I have an "81 Euro that has Bilstein Sport shocks and the factory sway bars. I am looking to upgrade and thinking of doing Sway Bars first and then later maybe Torsion Bars as well as a truss bar. So the question, what do you think? Any suggestions on brand and size of sway bars?
Thanx for any help
Jim Richards 11-10-2003 06:42 AM
Thom, you'll get more improvement by doing the torsion bars first. I think sway bars are for fine tuning your suspension.
What are your goals for your suspension upgrade? Street, street/track, dedicated track?
thomschoon 11-10-2003 08:15 AM
The car will be a street vehicle but ride quality is secondary. I would love to race again but I also would like to stay married so I will just build a strret beast and maybe do a DE or two.
Jase007 11-10-2003 08:31 AM
Thom:
I agree with Jim, torsion bars (TB) first, shocks / strus next and then sways. Having said that, on my '76 I have only done the shocks / struts (Konis, set one off full soft) with sway(s) in the box to install. Most likely will not do TB because is a street car and I have to drive on the ##$% roads of NoVA and DC.
My car runs 19mm front and 23 mm rear. If I stumbled across a set of 21 mm front and 25 mm rears I might put them in. Assuming all things are aligned in the universe and the other vehicles don't need any repairs... :lol:
There are several members with SCs that would most likely be happy to let you go for a ride to "shop" before you dive in. Best advice is to ride in it before you make the swaps.
Jason
estrellajon 11-10-2003 01:18 PM
I'm also interested in upgrading my suspension. Besides the alignment, can this project be done fairly easily with the proper tools.
Marc A 11-10-2003 01:26 PM
John:
Everything can be done with regular tools except the rear ride height adjustment which needs a special wrench to fit behind the spring plates. The wrenches abound in this area, and I'm sure you could find one to borrow. I have a couple that work and that you would be welcome to.
A dremel is indespensable on the front if ball joints are to be replaced, other than that a BFH, BFS, and BFVG will do the trick. :twisted:
BER 11-10-2003 01:53 PM
Thom,
I have a '84 911 (sans A/C and other un-necessary creature comforts) so my car and your '81 SC should weigh about the same.
I installed Sanders 22mm (frt) and 28mm (rear) torsion bars a couple of years ago. My car is used primarily on the street, but also sees 6-8 DE days each year. This setup is coupled with Bilstein sport shocks and the OEM sway bars.
The above setup is great on the street because it provides a firm ride with very little body roll. I have ridden in a '83 SC that had 22/30mm t-bars; that setup was a little to harsh and choppy on the street.
Installation is a "snap" for the front t-bars. The rears involve a little more work and knowing how to equate swing plate angles to ride height.
After installing the larger t-bars and the Bilsteins, I had the car corner balanced and aligned.
Hope this helps. Bruce
estrellajon 11-10-2003 02:00 PM
Marc, so you're saying the torsion bars are not as easy at it seems? How do you know what the actual ride height would be?
Dremel for what? Isn't there a ball joint remover that can be used.
Charlie Stylianos 11-10-2003 02:16 PM
Jon,
The tool is better suited for installing the castle nut rahter then removing it. After x years of being exposed to salt, rain, etc, the nut pretty much rusted to the ball joint and a dremel to slice the nut off works well and is less frustrating. Plus it saves wear/tare on the tool.
I have the castle nut tool if anyone needs.
Marc A 11-10-2003 02:57 PM
Jon:
The biggest pain is replacing the spring plate bushings which will need replacing unless some one else has done it before you. Ride height is a function of the position of the spring plate on the torsion bars and the postion of the torsion bars in the torque tube. There is about 3/4" adjustment on the stock spring plates, and the key is to get the initial ride hieght to within 3/4"
Many on the board have done this, and as long as you are willing to do the work, I'm sure that you will find 1 or 2 of us willing to help out as best we can.
Phone calls are free, house calls usually require food and beverage and a warm place to work.
Let us know.
