-   -   Need a New Racing Tire Air Gauge (https://dorkiphus.net/porsche/showthread.php?t=33330)
gogo911 10-03-2014 01:53 AM
Time for a new air gauge. Mine was knocked off its zero mark this past race weekend.
Looking for a digital model. Any make/models you would recommend or stay away from?
Der ABT 10-03-2014 09:31 AM
good discussion found here
http://rennlist.com/forums/997-forum...at-to-buy.html
personallly i use the longacre ones, dont know the models off hand but the two of them read exactly the same....i double check them every so often in case one goes outta wack.
i have had BAD luck with every digital gauge...borrowed or mine they have all been WWAAAYY off compared to my gauge....one was 10 lbs off.
i believe the longacre are best from 24 or 26-36 psi and each make has a range it read best at
roundel 10-03-2014 09:54 AM
I have two oil filled Longacres that I carry to the track. The oil is supposed to reduce the damage from impacts. I have a no oil one that I keep at the garage. All three are within 2# and have been in service for 5+ years. I have two oil filled ones because I gave on to my father and he prefers his digital pen style gauge. :roll:
I think this is the model I have:
http://www.speedmerchants.com/produc...-guage-0-60psi
Roo 10-03-2014 10:16 AM
I have an old Moroso 0-60 psi that is still within 1 lb at mid-scale after a recent calibration by a friend's shop.
If I was buying another gauge today, it would probably be the Longacre Magnum (on sale at OG for $59.00). Glow in the dark 3.75" face, swivel chuck, and a case.
N0tt0N 10-03-2014 10:20 AM
I have the larger Moroso gauge so that its easier to read for, um, <cough> people looking over my shoulder.... yeah, that's why. :roll: It is bulky, though, with the rubberized bumpers it is 4 1/4" across. +/- 1/2%
gogo911 10-03-2014 04:02 PM
I have a Longacre and a Moroso both analog. The Longacre was identified as inaccurate at my first SP race 4 years ago. Then I bought the Moroso which was dropped over the weekend. If I test on the same time, one shows 30 psi the other 22 psi. Both may be "wrong" as I have no "source of truth."
The sale at OG is on but all they have left are 0-15 or 0-30 psi units.
Lupin..the..3rd 10-03-2014 04:26 PM
Russell, I like the Intercomp brand liquid filled gauges. They seem very well build, made in USA, and give accurate readings.
Every digital tire gauge I've owned has died in under a year and it's not just batteries.
Trak Ratt 10-03-2014 06:49 PM
Me too only some like 10 years now. I worry less about absolute accuracy as same reading all the time. In other wards I don't care if it says 32 lbs,, when actual 34 but rather the gauge reads the same for the same amount of air in tyre.
Rob VN 10-03-2014 07:22 PM
I am happy with my Power Tank 8200 liquid filled gauge & hose. Four years of use.
Rob
TurboPooch 10-03-2014 10:05 PM
I bought the Longacre Magnum 0-60 because it is larger and easy to read with my old eyeballs. Has 1 lb increments and an angle chuck. Very accurate and has a nice case. Looks like OG has the older version like mine on sale. The newer ones now have 1/2 lb increments which I think is harder to read without my glasses.
Copyright ©2000 - 2025, vBulletin Solutions, Inc.
