Transmission Shop Recommendation in NoVA
Hi.
'95 M3 w/240k on what I believe is original tranny. My mechanic is telling me the lay/counter balance shaft in the tranny is bad and making the marbles in a tin cup sound I hear when clutch is not engaged. Before I hand over my paycheck for a new tranny, want a second opinion. Anyone recommend a good transmission shop in the NoVA area? Thanks. FLi |
We use County Transmissions for all our customer's work as well as for our enduro cars.
http://www.countytransmissions.com/ |
Thanks. Appreciate the recommendation. I will keep it in mind for the future. To follow up on my original post, based on the recommendation of several people, I changed the fluid in the transmission to a heavier weight. That has solved the problem. Cheers, FLi |
| All times are GMT -4. The time now is 12:11 AM. |
