-   -   Anybody have a heat exchanger wrench? (https://dorkiphus.net/porsche/showthread.php?t=3288)
rs911t 05-07-2003 07:59 PM
I need to remove the right HE to remove the cooler.
Thanks.
rickc 05-07-2003 08:12 PM
I have the extended hex head tool for the barrel nut configuration. I will be going through the Mclean area tomorrow later in the day,and Friday morning. Let me know if I should bring it with me to work.
Rick
'78 930
rs911t 05-07-2003 08:14 PM
I have 12mm nuts.
Yes, small, but I have 12 !! :D
rickc 05-07-2003 08:18 PM
12 mm barrel nuts with threaded ends or do you have the studs coming out of the heads and you need a 12mm offset wrench?
Rick
'78 930
rickc 05-07-2003 08:21 PM
Just checked the tool and its got an 8mm hex head on the end. I don't think this is what you are looking for.
Rick
rs911t 05-07-2003 08:26 PM
Studs coming out of the heads and I need a 12mm offset wrench.
rs911t 05-07-2003 08:35 PM
Nope - I need both. Those accessible thru the exchanger are barrel nuts (?) requiring a hex head. Looks like 8mm. I don't have anything narrow enough to fit thru the HE.
I clearly need a better hardware vocabulary!
Marc A 05-07-2003 09:32 PM
I have just what you need on both accounts. . . when and how do you want it :wink:
In addition, Charlie has my universal socket that come in various sizes, including 12, 13 & 14.
Charlie Stylianos 05-07-2003 10:04 PM
Greg,
If you need Marc's universal set, let me know.
I also have the 12mm offset and T-handle hex set if you need.
rs911t 05-08-2003 06:48 AM
Marc, I'm easy - what works for you?
