-   BMW Technical Discussions (https://dorkiphus.net/porsche/forumdisplay.php?f=96)
-   -   E36 Broken Subframe Mount (https://dorkiphus.net/porsche/showthread.php?t=30997)
tank 09-07-2013 11:37 PM
I took the subframe out to replace the bushings. Some sheet metal fell down and this was revealed.
There are repair plates available, but they require welding. Which I have never done.
The only thing I can think of to do is put enough of the car back together to tow it to a shop that can weld in the plates.
Currently the transmission, driveshaft, and rear assembly are out.
Any suggestions?
APKhaos 09-07-2013 11:46 PM
That's not the worst you'll see by a long stretch, so repair using the reinforcement plates look like a good option.
The Turner Motorsports kits provide all the plates and decent directions for the home wrench for around $100.
http://www.turnermotorsport.com/p-39...ement-kit.aspx
There's a fair bit of work involved to prepare for welding, the welding itself, and re-assembly. There may be a Dorki or two who might offer a good deal to do the welding for you if you take it to their place. Just thinking out loud on this.
smdubovsky 09-08-2013 08:41 AM
Cheaper at Bimmerworld;) Great guys and w/ them being in VA you'll have in a day or two.
http://store.bimmerworld.com/e36-rea...-kit-p541.aspx
Now that they are torn completely there is a lot more work involved. You first have to weld them back in (in the correct location!) and then weld in the reinforcements. If you catch them when its just a crack its much simpler.
Where in " 'merlend" are you? On lift or jackstands?
tank 09-08-2013 10:49 AM
Thanks guys. I don't suppose this would be a good time to learn MIG welding would it? Even if I managed that, it would definitely be tricky installing in the correct location.
I'm located in Bel Air, and the car is on jack stands. Was a bit worried about hiring someone to do the work, especially with how the car is sitting in a cramped garage and not very high up in the air (18" or so).
3 of the 4 mounts are still good, so it can be put back together and moved.
Lupin..the..3rd 09-08-2013 12:26 PM
Welding torn sheet metal upside down while laying on your back with 18" of room seems ambitious for a my-first-MIG project.
APKhaos 10-12-2013 12:13 PM
Possible the scariest video I've seen of subframe failure. E46 M3
Go to around 3:00 to see it during very sedate driving.
ausgeflippt951 10-15-2013 01:25 PM
MIG welding the underside of a car that's on jackstands is a frustrating experience for so many reasons.
