-   -   While the engine and transmission are out... (https://dorkiphus.net/porsche/showthread.php?t=30513)
84Targa 06-28-2013 05:01 PM
A friend and I are going to swap out my 915 transmission for another one - for my 1984 Targa. I have been around most of one and part of another swap but they were years ago and I can't say I remember everything very well. I have the Bentley manual (in black and white) and my friend is a very good amateur mechanic - but doesn't have any experience with Porsches. So wish us luck!
We will be doing the work in a second garage behind his house and he suggested I do more homework to put together a list of things to do while the engine and transmission are out. We don't have a deadline.
Any suggestions?
Jazzbass 06-28-2013 05:10 PM
Off the top of my head:
- Clutch
- Oil seals on the oil cooler and thermostat
- Cylinder head temp sender
VaSteve 06-28-2013 05:17 PM
Idiot light sender next to thermostat.
Lupin..the..3rd 06-28-2013 05:23 PM
While its out:
- replace the spark plugs
- do a valve adjustment
- check for any broken head studs
- inspect axles & cv boots, replace/rebuild as necessary
- inspect engine & transmission mounts, replace as necessary, or upgrade to wevo
It's quicker/easier to do all of these with engine out, so you might as well.
Since its a 915, you can also take the opportunity to upgrade to the brass shift coupling bushings.
84Targa 06-28-2013 05:53 PM
Thanks for the suggestions!
cmartin 06-28-2013 07:04 PM
Check the heater hoses and cables.
Trak Ratt 06-28-2013 07:33 PM
Originally Posted by cmartin (Post 449130)
Check and lub the heater hoses and cables.
ftfyb-o,
  • clean everything
  • shifter bushes (front and rear)
  • clean your oil level sender and top of the tank
  • replace rotor, cap and check wires
  • replace air filter
  • check your plug wires
  • fuel lines and rails
  • vacuum lines
  • if original consider changing clutch cable
  • little bushes in the throtle linkage (engine and trans linkages)
Dr K 06-28-2013 10:13 PM
Bill Miller lives in Darnestown. Swapping transmission is a breeze for him. Perhaps you could contact him and ask for "advice" - he's great, and close.
