-   -   LN Engineering Spin-on oil filter mod for 996 (https://dorkiphus.net/porsche/showthread.php?t=30001)
Elfer 04-08-2013 07:57 AM
Has anyone tried this? Pros/Cons?
http://www.lnengineering.com/spinonfilteradapter.html
Trak Ratt 04-08-2013 08:19 AM
Sounds like it would make a nice x-mass gift from your wife/kids. But why would you go to a larger mesh? Not sure there is anything wrong with the stocker(?) Why fix something that ain't broke? Might have more fun with a GoPro1
AznDrgn 04-08-2013 09:00 AM
Are you looking for a filter that is easier to change / cheaper or are you concerned with how clean the oil is actually getting? If it's the later you could always consider adding a bypass filter. Never seen one on a sports car but they are a pretty big deal for the diesel and equipment guys. Just a quick example from a google search http://www.fs2500.com/
Elfer 04-08-2013 09:25 AM
Just an easier change... I'm putting in nearly 500 miles a week...
Lupin..the..3rd 04-08-2013 10:04 AM
Get a GT3, then you can change the filter from above, instead of crawling under the car. This is the best solution.
AznDrgn 04-08-2013 10:15 AM
Don't you still have to crawl under to let the oil out?
Lupin..the..3rd 04-08-2013 10:23 AM
Use one of those topsider oil change devices that sucks it out from the dipstick tube.
Elfer 04-08-2013 10:32 AM
I wish....
Redshift 04-08-2013 11:11 AM
was thinking of picking up the adapter also. The stock filter is quite small.
Trak Ratt 04-08-2013 11:18 AM
How easier? Still uses cartridge, still needs to be seated perfect or it will leak
