-   -   911 aftermarket alarm removal (https://dorkiphus.net/porsche/showthread.php?t=29856)
principalyork 03-16-2013 01:15 PM
I have been removing old aftermarket alarm system from 76 911S. Thought I was careful about clipping wires recklessly but.... Now cannot get fuel pump to run at start-up or ever for that matter. Replaced fuel pump relay thinking I may have shorted it out.....(now I have the negative wire on the battery disconnected while I work;)Thanks!
Bird watcher 03-17-2013 12:07 PM
I have just removed an aftermarket alarm from my 86 911, jazzbass was very helpful with my work. See: DME relay Explained, and DME colour coding for a start. I found that wires were relocated in the fuse box to accommodate the after market alarm. I still am not getting power to DME relay pin 86 from pin 15 of the factory alarm, which is required in order to fire up the fuel pump. Assumption; faulty alarm module.
principalyork 03-19-2013 06:26 PM
Thanks, Bird watcher! Very helpful. But as an electronic newbie, what are the "pin 15" and DME relay Pin? Is pin 15 in the fuse block? Where is the DME on a 76 911? Thanks for your help.
Jazzbass 03-19-2013 07:11 PM
You don't have a DME or DME relay. That started in 1984. You have the old CIS fuel pump circuit. If you can wait a bit, I'll post explaining exactly how the CIS fuel pump circuit works. Got some work stuff/taxes to do first, though.
principalyork 03-20-2013 11:07 AM
Thanks a bunch!!!
Tom
1976 911S
2001 Carerra 4
Potomac-Greg 03-20-2013 03:42 PM
Cut the red wire. NO! Cut the blue wire...
