-   Tools Needed/For Loan (https://dorkiphus.net/porsche/forumdisplay.php?f=55)
-   -   german hose clamp tool? (https://dorkiphus.net/porsche/showthread.php?t=24824)
VaSteve 02-08-2011 07:14 AM
I seem to recall there is a special type of pliers to remove those factory installed hose clamps on newer german cars. Anyone have a link to what I might be looking for? In using that tool, can I reinstall it as well? I'm working in a tight space and my principle concern is removal. Reuse would be nice.
Trak Ratt 02-08-2011 07:40 AM
Like this?
http://forums.pelicanparts.com/uploa...1145113973.jpg
http://forums.pelicanparts.com/porsc...tion-hose.html
I easily found the link and Oetiker's website using Google :roll: Bet even you could have too if you'd tried :p
Vicegrip 02-08-2011 07:44 AM
Are you talking about the spring loaded ring clamps? There is a cable driven tool that lets you reach into hard to get places and pry the clamps open. the handle portion of the tool is remote to the head. Snap on, Favcon and UI think some others make them.
Dr K 02-08-2011 07:58 AM
For installation, I made a tool similar to the Oetiker one shown by purchasing an end-nipper at Harbor Freight ($5.79) and grinding the sharp edges off so it wouldn't cut the clamp. But that Oetiker one looks pretty nice and isn't all that expensive. I did write about my experience (with photos), but I think it's buried in the race car build thread, and I don't have time to look for it.
cmartin 02-08-2011 12:47 PM
Removal of fixed/1 time use clamps? A set of dikes. If you are removing hard to reach adjustable clamps the tool Vicegrip mentioned is very useful.
I think this is the version I've used
http://lh4.googleusercontent.com/pub...8e7ssqSHtACRL_
VaSteve 02-08-2011 07:20 PM
Thanks. I tried with regular pliers and couldn't get it undone. The I dropped the pliers and they are struck inside the panel near the wheel.
Dave I like the personal touch you provide. I did google on "german hose clamp tool" and the porn links I got back would make even you blush.
Trak Ratt 02-08-2011 07:39 PM
I doubt that but from your answer I take it there weren't any
Clarke 02-08-2011 07:42 PM
Steve, what is the clap that you are trying to remove. Is this on the e46?
VaSteve 02-08-2011 07:49 PM
She could get the clamp off!!
Yes, hose to the headlight washer....fluid is leaking all over the garage and the low fluid light is mocking me! There's no room to work and the other end is buried way up under the bumper.
slbates 02-08-2011 07:53 PM
2 Attachment(s)
If you are talking about the ring clamps, Sears has a decent cable operated set. I bought them when I changed out the coolant tank on my 996. I think Matt may have told me about these. Looks very similar to the others shown. I'm located near 28/50 if you need to borrow. BTW, Porsche issued a TSB to replace the ring type clamps with the screw type clamps.
