-   -   Dang... I need Heat! 914 help! (https://dorkiphus.net/porsche/showthread.php?t=24472)
Casey914 12-02-2010 10:45 AM
My 914 has none of the parts that are required for heat. All were removed years ago and i have come to the conclusion that it is necessary for enjoying the car for more than 4 months out of the year.
Car has rotten heater boxes so will need the whole batch.
Does anyone have an exhaustive list of what is required or know of a place where all can be sourced? Would prefer not to buy new heater boxes...
Car is a 1.7L
Casey914 12-02-2010 10:53 AM
This is what Auto Atlanta Sells...
Our Package Includes The Following:
2 Heat Exchangers (L & R), 2 Rear Branch to Heat Exchanger Clamps, 1 Bursch Muffler System, 2 Warm Air Elbows, 1 Nut & Bolt Kit 2 Branch Pieces (L & R) (Used), 1 Heater Cable Set , 4 Copper Exhaust O-rings
2 Heater Hoses, 12 Sheet Metal Screws, 2 J-Pipes (Left & Right, Used) 2 Muffler Gaskets, 1 Rear Muffler Bracket, 2 Heater Control Boxes (Left & Right), 2 Barrel Nuts, 4 Heater Hose Clamps
2 Impeller to Branch Clamps (Left & Right, Used) 8 Copper Locking Nuts
1.7 or 1.8 Heater Package ... BSTA 1718 $1,850.00
2.0 Heater Package ... BSTA 20 $1,850.00
Definitely dont need another exhaust system but that gives me a good idea of what is required.
HoodPin 12-02-2010 10:56 AM
Something like this could be a temporary alternative:
http://www.amazon.com/gp/product/B003ZJ04P4/ref=pd_lpo_k2_dp_sr_2?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000IXTGHW&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0GKR6E527VPBA02DRBYQ
Prolly need a heavy guage wire connection to the battery. But does work. I bought something similar for my race car to help defrost the window during Feb/Mar events. :D
Casey914 12-02-2010 11:16 AM
Thanks Tony... i feel that getting the heat to work would add to the resale value of the car... so gonna concentrate on the factory alternative :)
cmartin 12-02-2010 11:28 AM
Good reference
http://www.pelicanparts.com/catalog/...EXHhtr_pg1.htm
Section 202 http://www.porsche.com/all/media/pdf...SA_KATALOG.pdf
Lupin..the..3rd 12-02-2010 11:57 AM
Burrito Supreme and a Nachos Grande from Taco Bell. You'll warm up the cabin in no time.
Chopper Dropper 12-02-2010 12:13 PM
How much gas is in it Casey? ;-)
Dirk
Vicegrip 12-02-2010 12:23 PM
the down side is you eventually give in and open a window.
$1800 for heater system? Buy a rusty project 914 for that strip it and sell off or toss the rest out.
Casey914 12-02-2010 05:03 PM
I think i should be able to get all used parts for ~600.
Casey
JmuRiz 12-02-2010 06:31 PM
Hmmmmm, I may know someone that's going to get rid of a full 2.0 setup. If I'm not mistaken, it all bolts right up (but check with an expert to be sure). I have the fans, tubes, a bursch muffler, and SSI heater boxes.
It's all still on the car, and I was thinking of trying to sell the whole package...but may change my plans to help a local. Wouldn't want a whole 2.0 with webers setup would ya ;)
