-   -   Rear calipers, pistons look sealed by rust... (https://dorkiphus.net/porsche/showthread.php?t=23435)
marsosporsche 06-21-2010 10:08 PM
Hello, yes today i started to rebuild the calipers, and surprise! the first rear one as one piston stock inside, and the oder caliper, both are stocked.
For the front on no problem at all.
I have tried the brake pedal, and the air compressor and they won't move.
I've soaked them tonight with penetrating oil.
Any tips or trick?
Thank you.
Trak Ratt 06-21-2010 10:10 PM
Get a set from your FLAPS ~$65 - $75 each exchange...
marsosporsche 06-21-2010 10:12 PM
Sorry what do you mean by FLAPS?:shock:
Trak Ratt 06-21-2010 10:21 PM
Friendly Local Auto Parts Store :D
marsosporsche 06-22-2010 08:35 PM
After 24h with the penetrating oil.... they came off:D
i'm waiting for the hard brake line that got damaged in the past.
and hopefully back on the road this weekend.
Josh@ECS 06-22-2010 08:53 PM
PB Blaster is one of the best pene oils for this sort of issue. I also will use a C clamp sometimes to compress the piston inward all the way (and to hold the other piston in place) then hit it with the air. Alot of times working it back and forth helps.
Glad to hear you had success anyways!
Dr K 06-22-2010 11:58 PM
I've got a front driver's side hard brake line if that's the one you need.
marsosporsche 06-23-2010 06:25 AM
thanks but it was the rear one.
Should get it today.
