-   -   Rear torsion bar question (https://dorkiphus.net/porsche/showthread.php?t=23128)
OldTee 05-11-2010 01:22 PM
I am about to replace my rear torsion bars going from stock 24.1MM to 28MM. The angle for the torsion plate inclination is 40 degrees. What is recommended for the upgrade? More? say 44 degrees? Less (don't think so) say 36 degrees?
I suspect a lot of trial and error, but a starting place would be helpful.
ARF
cmartin 05-11-2010 01:29 PM
I've used this and it was dead on.
http://www.rennlight.com/cgi-bin/spring.cgi
tdatk 05-11-2010 01:31 PM
2 Attachment(s)
John,
I installed hollow 28mm t-bars last year. I used 23-24 degrees measured on the top of the unladen spring plate. Slightly lower than euro ride height.
Trak Ratt 05-11-2010 01:52 PM
Tim's right final figure is really based on ride height. If you a real happy with what you gotz, just look at the table. See where you need to go to have same ride height with new bars.
22mm front and 28mm rear is what I had with stock sways. IMO very sweet combo for street and track.
roundel 05-11-2010 03:01 PM
VaSteve gave me this link and Vicegrip used it to help me.
Dr K 05-11-2010 04:51 PM
Please look up 3 posts... :roll:
Trak Ratt 05-11-2010 04:54 PM
If those other ones don't work try this one http://www.rennlight.com/cgi-bin/spring.cgi
Vicegrip 05-11-2010 06:22 PM
There is a link somewhere around that has a great angle calculator. Handy little bit O code and landed Roundel's rear ride hight close to spot on.
Just found it. http://www.rennlight.com/cgi-bin/spring.cgi
OldTee 05-11-2010 07:39 PM
Thanks all. Spot on responses.
PS: to Dr. K
It is OK to leave your dirty laundry in my shed. I found two dead mice and the squirrels won't come within 50 feet. A full week and it will probably drive out the termites!
ARF
