injector pulse?
Anyone know what would cause the ECU to drop injector pulses?(924S)
Have you read through Jazz's explanation and tech stuff on the "brain?" Lots of good info and most is good for '24s/'44s.
Bad injector transistor. Bad solder joints in the DME. Open the DME and look around see if you see anything obvious. Check out FRWilks site in the Motronic section - 944 DME specific stuff.
| All times are GMT -4. The time now is 05:54 AM. |
