-   Porsche & BMW Parts For Sale/Wanted (https://dorkiphus.net/porsche/forumdisplay.php?f=43)
-   -   Wtb: '88 944 Dme (https://dorkiphus.net/porsche/showthread.php?t=16953)
N8N 04-05-2008 09:09 PM
Wtb: '88 944 Dme
looking for p/n 944 618 121 05 or stock chips for same. Car has Autothority chips in it now and with the price of fuel would like to be able to use something other than premium. PO lost stock chips... grr... let me know if you have
thanks,
nate
Jazzbass 04-05-2008 09:49 PM
I might be able to help you out. Sent you a PM.
jsilverm 04-05-2008 11:42 PM
Youre supposed to use premium with the 88s even with stock chips.
BlackTalon 04-07-2008 10:16 AM
Not that it isn't a good, idea, but seriously, you're talking about saving 2.5-3% of the price of a fill-up by going with 89 instead of 93. When you are at $3.50/ gallon, knocking off $0.10/ gallon doesn't do a whole lot for the wallet.
It actually would have been a better idea to try this when premium was $1.20/ gallon vs $1.10 a few years back, netting closer to a 10% savings.
N8N 04-08-2008 09:04 PM
you have a point, but I also have an intermittent issue with the car running really rich on a cold start and also sometimes not running right under heavy throttle in very hot weather. I figure before I start going nuts checking all the sensors that a set of stock chips might not be a bad idea. Also then I could see if they really did make the car feel any faster :)
nate
dhshivers 04-08-2008 10:17 PM
If your are going that way with de-tuning check with your mechaniac. Also, talk to Oklaforeign to see if they have the parts you need.
N8N 04-13-2008 01:18 PM
Still looking...
if I could even borrow one for a while that might help
can someone tell me if there are any significant differences between 85.2-87 and 88 DME's?
thanks,
nate
jsilverm 04-13-2008 05:28 PM
Im pretty sure that the 88 DME will only work with an AFM from an 88. The programming in the DME is different, has ahigher redline etc.
N8N 04-13-2008 05:35 PM
Goshdarnit to heck, 'cause I think I had a line on an '87.
oh, well, thanks for the reply anyway, just next time tell me what I want to hear, mm-kay? (not really, cause then I'd be pissed when my car didn't run.)
nate
