Jacking up front end
Anybody know a good way to jack up the front of the car so you can put jack stands under both the A-arm caps? Here (I hope the upload worked) is method that appeared on the Pelican site recently. Looks kinda crude to me. Comments?
I use the bar that's right behind the front air dam (that protects the A/C). Are we talking about a 911 here? Is that pic of a 911?
I use the alum. cross member where tha A-arms meet but If you want to do it this way get a board long enough to reach between, jack in middle like you are and place stands under board. Or just keep jacking and place stands. Still like cross member ends better.
I jack my '76 targa up exactly where the picture has the jack. Most times I don't even use a piece of wood [rubber padded jack].
There isn't a lot of weight there and car goes right up easy-peasy [tech term]. :) |
i use a board long enough to extend over the caps and put the stands under the board. 914 front end is light though....
Kurt just lifts his car by hand - very LIGHT! :D
| All times are GMT -4. The time now is 03:25 PM. |
