-   -   Transmission cleaning (https://dorkiphus.net/porsche/showthread.php?t=15374)
pookie 10-21-2007 04:09 PM
My transmission is nasty on the outside and nasty on the inside of the bell housing. What can I use to clean the outside? What can I use to clean the inside? Do I have to use brake clean or a carb cleaner on the inside?
The "while you are in theres" have already started :roll:
88carrera 10-21-2007 05:44 PM
I would use kerosene. Not as toxic as brake kleen and cheaper too.
Rick V 10-21-2007 05:50 PM
Greased lightning and a garden hose, and you have yet to scratch the surface of WYIT
hoophead 10-21-2007 05:58 PM
High pressure sprayer. Don't aim directly at the seals. Be sure to wear black clothes ;-)
Lupin..the..3rd 10-21-2007 06:24 PM
A toothbrush and some aluminum polish. Follow up with a dremel and polishing "bit". Two coats of wax after that. You'll never win the concours with a transmission that doesn't shine. :cool:
Dave O 10-21-2007 07:09 PM
Full strength Simple Green and a brush has always worked well for me. Wash off with water from the hose in the driveway. :D
Trak Ratt 10-21-2007 07:50 PM
X2 except I'd use a HP washer. And run the rinse water through some rags just for the epa :p
Rick V 10-21-2007 08:22 PM
Wait a min. Arn't you in W.Va? Just take into the bath with you.
Trak Ratt 10-21-2007 08:26 PM
Ha, ha, he wants it done before x-mass :lol:
pookie 10-22-2007 07:24 AM
Yeah I'm in WV, but I'm not from WV. I have all my teeth for one. I didn't marry my sister for two.
