-   -   981 cayman with bad coil on #6 (https://dorkiphus.net/porsche/showthread.php?t=39941)
Otto 08-06-2019 12:24 PM
not more than two miles from summit point sunday after my last session, i got a check engine light and a message indicating it was ok to continue driving, but it went into limp mode and disabled just about everything
i did a slow drive home, some 40 miles, with a sick car that vibrates under load
next morning, my bluetooth obdlink mx indicated a few codes, and misfires on #6
tom at tpc suggested i use the cobb to get the codes and it showed more codes, but they all seem to start with a bad coil on #6
11,000 miles and a bad coil??? it is a 2014, and i guess they could have aged out
it is a cpo car, i need to decide which dealer to take it too
i am taking a poll - tysons, arlington, or silver spring???
also, should i drive it, or make them tow it? i am 30 miles from tysons, further to arlington and silver spring
Dandelion 08-06-2019 02:44 PM
Coils #6 is usually the one that goes bad - not uncommon on DE Caymans (ask Michael Kuehn).
BlackTalon 08-06-2019 03:27 PM
Tysons. With Silver Spring being #2 choice (really based only on the distance from you). I really haven't heard anything positive about Arlington. It's owned by Rosenthal these days and I understand the 'luxury car' experience is lost on them.
trytryagain 08-06-2019 03:36 PM
Otto, I had this problem and had to drive home from VIR. If you turn the car off and back on the problem may temporarily resolve. I did this at least half a dozen times to get out of limp mode—it would then be fine for some miles.
The issue I believe is heat related and is why I added a center radiator and also make it a point to cool my car down after each session. I don’t park until the oil temps are back into the teens. Number 6 is the most frequent failure and is relatively easy to change. Ed Wright and I changed his at WG (I carried a spare coil), and he drove back no problem.
trytryagain 08-06-2019 03:39 PM
Originally Posted by trytryagain (Post 625115)
Otto, I had this problem and had to drive home from VIR. If you turn the car off and back on the problem may temporarily resolve. I did this at least half a dozen times to get out of limp modeóit would then be fine for some miles.
The issue I believe is heat related and is why I added a center radiator and also make it a point to cool my car down after each session. I donít park until the oil temps are back into the teens. Number 6 is the most frequent failure and is relatively easy to change. Ed Wright and I changed his at WG (I carried a spare coil), and he drove back no problem.
Also should mention that the current coils have a higher part number and may be improved. I had them all changed when it was time to change the spark plugs.
Lara 08-06-2019 04:22 PM
And Jim and I bought extra coils right before PorscheFest on Jim C's recommendation at Tech!
tbernard 08-06-2019 06:09 PM
this!! A couple extra coils should be in the spares bin you take to the track.
cmartin 08-06-2019 06:36 PM
Swap with another to make sure the code follows.
RV4Flyer 08-07-2019 06:26 AM
I had my #6 coil go bad as well in my 14' 981 last year. Was under the CPO warranty so had it fixed at the dealer. They said it is a common problem and there are updated coils they use now, they are a different color so you can easily tell. I have an extra in my track kit just in case. It is an easy fix so I wouldn't sweat over who does it so save yourself some effort. You could probably just do it yourself.
Otto 08-07-2019 09:35 AM
man, had i known just restarting the car a time or two might have resolved the issue for the drive home!
i feared it would not start again, and the dash message said i could drive on carefully
limp mode is no fun
so, in addition to a coil, one wonders what other spare parts should be kept on hand for a 981 cayman s for hpde events. and then, there is the space, tools, skills, etc, to make use of them. i am not real big on wrenching, on or off the track myself, but i know there is help from my pca friends, perhaps given beer and food :-)
here are my current codes, if anyone would like to comment, please do so...
0x773
Uc150
Uc151
Uc153
Uc143
Uc322
Uc323
Uc140
Uc152
Uc130
Uc126
0x753
Uc140
Uc155
Uc447
the car seems to be running fine now
the dash info messages are no more
i took it for a spin last night
but these codes persist, and while i can clear them, i thought i would leave them for tysons porsche to see
i should have taken a photo of the dash info messages, but i did not think of that
i was going to take it to the dealer for cpo service anyway, as i have a developing door panel fitment issue, and the driver window switch has an intermittent issue
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
