I made a bit more progress this weekend by replacing the hardware for the rear rotors and installing all rotors and calipers. Still need to attach the new brake lines.
Rotor ready to be reassembled. http://i983.photobucket.com/albums/a...psgukjydgd.jpg And assembled. http://i983.photobucket.com/albums/a...ps6wqddxnc.jpg On the car. http://i983.photobucket.com/albums/a...psp3dfb8ce.jpg http://i983.photobucket.com/albums/a...pstslcwxpx.jpg I also received the 90 degree Schrader valve adapters for my rear shocks, so I went ahead and upgraded the valve cores to high-pressure cores. http://i983.photobucket.com/albums/a...psikpywnof.jpg For comparison purposes - standard valve core on the left - high pressure cores on the right. http://i983.photobucket.com/albums/a...psfxt7qgcl.jpg Some adapter details. http://i983.photobucket.com/albums/a...pschhdzevq.jpg http://i983.photobucket.com/albums/a...psjshlkgno.jpg I just hope they'll hold pressure when installed. |
Oooooooooooooooooooooooooooooooooooo
Pretty!
P.S. What are the S'Mores doing on the ground under the new fronts?!?!?! |
Just chillin'. I got some new titanium shims to replace them with.
Made a little more progress last night by installing the transmission.
I started by removing the IMS bearing shaft nut, which is where I think the oil is coming from. Grimy. http://i983.photobucket.com/albums/a...psv9m6yiev.jpg Cleaned up. http://i983.photobucket.com/albums/a...psgfgdbssk.jpg Nut reinstalled and torqued with some Drei Bond on the face of the nut. http://i983.photobucket.com/albums/a...pscvxbwrjg.jpg Everything looks pretty clean. http://i983.photobucket.com/albums/a...psu7wyg7if.jpg Flywheel installed and torqued. http://i983.photobucket.com/albums/a...pscqjrqcvr.jpg Clutch disc. http://i983.photobucket.com/albums/a...pspdqejhpt.jpg Pressure plate. http://i983.photobucket.com/albums/a...psnbs3m434.jpg Transmission. http://i983.photobucket.com/albums/a...psd1xefglc.jpg |
Nice! I need a week off!
I know. The schedule is rather compressed because of Zone 2. It'd be ironic if the weather screws us after all this work.
| All times are GMT -4. The time now is 09:47 PM. |
