Thanks Mark! Great to hear. I just checked your website and noticed you have the 83 compound on sale. For about half what the 08 is going for. Is there any merit to considering this? IIRC it's a pretty aggressive pad from a wear standpoint, yes? Might just be cost effective (and 'sanity effective') to go with the 08 anyway. Looking forward to the 08 -- been a long time coming for the 'fo-fo. |
IIRC 83 will cause you to hit you face on the steering wheel the first time you use them after they warm up. They are for the worst of the worst conditions such as Nascar short track.
Don't overthink it -- they are a wear item, and will have a short life if you track the car. Pick a compound and give it a try. You'll need a new set before you know it, and you can try something else at that point if there are elements of the first set you did not like.
Thanks guys. I've got about one more weekend's worth on the Hawk Blue's, so I'm looking forward to swapping. The Blues are OK, but I haven't been pleased with their feel characteristics they exhibit when they get near the end of their life. Don't inspire as much confidence as the '97's do. |
And x2 what TR says. We keep some used pads around for backup. Often re-sort thru the used pads and keep the 4 best ones as backup. |
I've had Hawk HT-10s crumble. Did not have that issue with Pagid Oranges. But the HT-10s only crumble when worn down a bit less then backing plate thickness (they start to overheat).
Please note that all track pads DO NOT behave in exactly the same way. About the only generalization you can make is that track pads will last longer and stop much better at track events then street pads. |
heat cycles take a toll on the pad materal.
Thanks TR and Tony -- good advice. That's actually what I've more-or-less been doing over the last few years (building up a collection of almost-dead pads). I'm somewhat trying to limit this collection; So far I'm up to ~3 extra sets of race pads and ~5 sets of street pads! I'm sure that for some of you, that is chump change, but I'm currently trying to get rid of parts,not add... :D
| All times are GMT -4. The time now is 03:40 PM. |
