-   -   Cayman S (987.1) HPDE Season Prep (https://dorkiphus.net/porsche/showthread.php?t=33960)
987kmns 02-08-2015 09:12 PM
Originally Posted by Rob VN (Post 509039)
I've been exploring different approaches to replacing the "control arms" on my car after picking up on Tom's comment about changing them every 3 years. Also my wife says forget about getting a GT4.
#1 The ultimate setup IMHO is the ERP pro series which after selling off the RSS LCAs would cost about $2k and the most work to install end would endlessly confuse my alignment dude. He is OK with the RSS LCAs & bump steer toe links.
#2 The next option would be the Tarret tension/compression struts that would cost about $1.3K and be fairly easy to install after setting the lengths to match the stock pieces.
#3 The next option would be installing the stock arms that cost about $1.1K and again be fairly easy to install.
#3A The out of the box solution that I don't know how to implement would be to get spherical joints to fit in the stock arms since we both have hydraulic presses....has any one tried this ? http://cad.aurorabearing.com/viewite...led-ptfe-lined
In the front, I have 997 cup LCAs and thrust arms. In the rear, it's all stock except for the TPC toe arms. No changes are being made to the front. For the rear, I got the aluminum thrust arm bushings for the LCAs from TPC and I just ordered new OEM thrust arms.
I think that option #1 is the best. It's just a matter of cost. I don't think that there is much time to be shed on the track between your current setup and the ERP pro setup, but the ERP setup is definitely a more race car-like setup.
Originally Posted by Intubator (Post 509044)
Another option: Install new polyurethane bushings on your existing control arms. Here's a company that sells them.
http://powerflexusa.com/
I am seriously considering these in the black version all around and possibly the front kit which allows for camber adjusting with the inner bushing.
That's a very good option as well. I would consider this for the stock LCA inner bushings.
Rob VN 02-09-2015 08:55 PM
Powerflex doesn't have bushings for thrust arms
Mihnea,
It looks like Powerflex doesn't have bushings for the thrust arms. They have bushings for everything else. I'll talk to them.
Rob
987kmns 02-09-2015 09:25 PM
Ok. Please report back.
Rob VN 02-10-2015 02:06 PM
Contact with Powerflex, no joy: they don't have these bushings. My request was sent to the UK where their engineering is located.
Update: ECS doesn't sell just the bushings either
Intubator 02-10-2015 03:19 PM
Check ebay, I think I saw the thrust arm bushings being sold by the UK branch. They ship to USA too.. I believe I also saw them on the Powerflex UK website as well.
Rob VN 02-10-2015 04:07 PM
OK I'll check that out
Intubator,
Thanks,I'll try looking there. The US Powerflex site didn't list them.
Rob
N0tt0N 02-10-2015 04:25 PM
I have the OE arms I took off in case you want to experiment. 986, though...
Rob VN 02-10-2015 04:25 PM
No Joy on thrust arm bushes
No luck finding the bushings on UK Powerflex website or eBay.
http://www.powerflex.co.uk/black-ser...9+-2808/1.html I am looking for the other end of #2 in the website suspension diagram
I did find the TRW arms at Parts Geek for about $640 for two front and two rear arms. That is about $400 less than the Porsche arms that emanate from the same factory. Our cars may not be old enough to warrant development of these bushings?? Powerflex has every other kind of bushing imaginable but not for the Cayman thrust arms. If I get any word from Powerflex in the UK I will share it.
Intubator 02-10-2015 04:46 PM
Sorry to lead you on a thrust bushing goose chase Rob VN...
Rob VN 02-10-2015 08:30 PM
No problem
Intubator,
No problem, searching is half the fun. I'm holding out for Powerflex to come through.
Rob
