I always feel so guilt looking at Mihnea's car. Inside and out it's always so clean! Nice work as always.
That's freakin' awesome! You work much faster than I do! LOL
P.S. Are those really Ferrari sweat pants? :shock: |
Awesome work, noticed the pants too.
You need an impact gun! |
I recommend a nice 3/8" gun. Can basically do everything except the stuff that you probably want to use a breaker bar for. As a casual hobbyist mechanic I got a dewalt a few seasons back... http://www.amazon.com/DEWALT-DCF883M.../dp/B00BWFIKZO saves tons of time. I take it to the track and use it to take off wheel nuts too. Almost painful watching you loosen all those little bolts by hand :)
I will actually have a Bosch for sale shortly - will list it this week
Just a quick update. I got some more parts in the mail:
http://i983.photobucket.com/albums/a...psltltf2xe.jpg And I separated the front rotors from the hats. Then, I did my best to spruce up the hats a bit. The front hats are off to GiroDisc for re-ringing. http://i983.photobucket.com/albums/a...psbwqx73mi.jpg And separated. IMPORTANT NOTE: I found that some of the screws that are supposed to hold the hat and rotor together were loose. I found that some (2 or 3) had sheared off! I found that many of the captive nuts were deformed and starting to crack or already cracked. This is a major safety issue! I am also ordering a new hardware set for the rear rotors to replace the old hardware even though I am not replacing the rotors. I had no idea that this hardware needs to be checked and replaced. This will be added to my track inspection checklist. PCA track safety inspectors - this should probably be checked on cars with aftermarket floating rotors! http://i983.photobucket.com/albums/a...psr01csy33.jpg http://i983.photobucket.com/albums/a...psnxhwkzua.jpg In the process of cleaning. http://i983.photobucket.com/albums/a...psnvhomxtb.jpg http://i983.photobucket.com/albums/a...psbwdvseob.jpg http://i983.photobucket.com/albums/a...psxqi3vjwc.jpg |
Suspension arm thoughts
Mihnea,
I've been exploring different approaches to replacing the "control arms" on my car after picking up on Tom's comment about changing them every 3 years. Also my wife says forget about getting a GT4. #1 The ultimate setup IMHO is the ERP pro series which after selling off the RSS LCAs would cost about $2k and the most work to install end would endlessly confuse my alignment dude. He is OK with the RSS LCAs & bump steer toe links. #2 The next option would be the Tarret tension/compression struts that would cost about $1.3K and be fairly easy to install after setting the lengths to match the stock pieces. #3 The next option would be installing the stock arms that cost about $1.1K and again be fairly easy to install. #3A The out of the box solution that I don't know how to implement would be to get spherical joints to fit in the stock arms since we both have hydraulic presses....has any one tried this ? http://cad.aurorabearing.com/viewite...led-ptfe-lined Scary about finding the hat bolts loose. The bolts are usually drilled for safety wire. I'll be checking mine too, they aren't safety wired yet. Rob |
Another option: Install new polyurethane bushings on your existing control arms. Here's a company that sells them.
http://powerflexusa.com/ I am seriously considering these in the black version all around and possibly the front kit which allows for camber adjusting with the inner bushing. |
| All times are GMT -4. The time now is 08:40 PM. |
