-   -   to girodisc or not to girodisc (https://dorkiphus.net/porsche/showthread.php?t=39664)
Otto 04-24-2019 01:23 PM
Originally Posted by BMAN (Post 621553)
I have a set of 18” track wheels from a 987.2 on our 981. Fitment is fine. Tire diameters for the 981 are greater, +/- 1”, front and rear IIRC.
Have your tried your 987.2 wheels?
the 987 track wheels are toast
Otto 04-24-2019 01:37 PM
i am thinking if i use the supplied 20 inch p-zero tires that are on the car next weekend, i will not over drive the car
it will be abit before i have roll bar, seats, and harness anyway
i think i would like black wheels
BMAN 04-24-2019 03:39 PM
opps, sorry!
trytryagain 04-24-2019 04:20 PM
“plan to only drive the car at 80% until i get it all sorted”
Is that 80% of 120%? JK!
roundel 04-24-2019 11:04 PM
Why did Porsche think it acceptable to enclose the caliper so pads can’t be swapped and use steel bolts threaded into aluminum? Studs ftw.
+1 on PFC 08. I got amazing durability and no fade and great feel until the pads were down to 2mm. But I brake only when waiting for VASteve to point.
Dandelion 04-25-2019 10:42 AM
Stiffer caliper with a closed back.
Yeah, that part was stupid.
edw 04-28-2019 06:06 PM
981S brakes
Sorry I didn't see this till now. I ran stock rotors the first season with my 981S with Pagid Yellows and the stopping power was fine. I did upgrade to Girodiscs and see the main benefit as longer life (fewer rotor swaps) and cooler brakes because they are slightly larger diameter and dissipate heat better. I swear the pads are lasting longer, but maybe I'm just braking less! Still running my first set of Girodiscs after quite a few events. I do recommend replacing the caliper bolts with studs - less risk of stripping the threads in the hub - an expensive mistake. Also, I found no need to replace the master cylinder. The 987s benefitted greatly from the GT3 master cylinder upgrade - much firmer pedal feel. But the 981S must have a 911 master cylinder - once I went to braided lines and the Giro's, the pedal feel is very firm and confidence inspiring. See ya at Pitt!
Cheers
Ed
981S #37
Originally Posted by Otto (Post 621455)
is it better to go with a bbk from stoptech, ap, or brembo for $3k-$4k per axle or to simply go with existing calipers, caliper studs with spacers, and slightly larger floating disc rotors from girodisc for way less than $3k for both axles?
i am leaning girodisc
i would also upgrade the brake lines, add a trw/gt3 master, and gt2 front brake ducts, along with wheel studs
and this is the big ask!
do any of my pca friends with a lift want to help make this conversion this saturday?
981 cayman s wrenching experience would be helpful :lol:
crazy i know
otto
Otto 04-29-2019 12:42 PM
thanks ed
i don't know why i was thinking the brakes on a 981 were not much different than those on a 987, but the front brakes are definitely must improved
dirk did say i was over thinking it again :-)
for now i am going to burn the stock rotors that are on the car
then we will see
so i have a gt3/trw master new in a box for sale
i also have a set of gt2 front brake ducts - do you think those are worth putting on?
so i am going with pagid yellow on front and pf08 bads rear for now
i will most likely replace rotor discs with sebro slotted
Cheers
Ed
981S #37
Trak Ratt 04-29-2019 03:20 PM
Always worth getting more air to brakes! Keep the MC, you know you will want it next month.
arob 04-29-2019 05:17 PM
:shock::lol:
