The cheating thing. Did Tech for a bunch of CR weekends. At first I :? with a bit of :lol: then it was more :roll: but after a while it was :grrr: |
Very exciting JD! Glad to see you back in the fray -- miss you boo.
here's everything going in to the I build. very nice that the car already had cage and suspension.
Racetech RT4119HRW Schroth Profi II harness Schroth right side net KMP cup wheel + paddles + quick release TPC PDK cooler TPC Engine oil cooler TPC power steering cooler Bilt gen2 header/midpipes/exhaust/tip GT3 Master cylinder 996 GT3 brake booster TPC Carbon Switch panel Remove remaining interior/PCM + install front bar Radio + harness + antenna + IMSA intercom CCW c10 wheels (x2) Hoosier R7 (x2) |
How are you going to race on just 2 wheels and tires? Like this?
https://youtu.be/Ii8d0F_Bd84 Hate to say it, but it looks slow... |
Adding solid engine mounts and solid trans mounts to the build.
Dr. Chan seems to think ~650lbs of drivetrain will move around a lot at high lateral g given the soft stock mounts, as they are designed for some modicum of comfort. COMFORT! Well, we'll be having none. Of. That. Seems a reasonable concern. Also, it'll feel more #racecar and thusly more badass when my fillings are shaken loose in the middle of 17 at Sebring next year. |
Proud of you JD... glad to see I assisted in creating a monster :)
2x Semi on the engine but that could be old school thinking anymore.
Good news everyone!
Engine mount is indeed semi-solid http://www.rennline.com/Wevo-Semi-So.../S%2D111%2DW9/ |
| All times are GMT -4. The time now is 08:06 AM. |
