-   -   Uh oh. Ryan's head exploded at 6:36 Eastern Standard Time (https://dorkiphus.net/porsche/showthread.php?t=33565)
Ryan 11-11-2014 10:43 AM
Originally Posted by ausgeflippt951 (Post 500263)
Dumb. I get the weight increase for H (sorry Ryan), but the wing rule doesn't seem to make much sense.
Hell Ryan, you may pick up a mile-an-hour or so on the straight by getting rid of the wing. May as well try and be as slippery as possible.
Also weight loss for 993's -- that's good to hear. Had a good conversation with Walt back in Aug re: proposed rule changes for a few of the classes. Hope it helped.
I'm the one who actually proposed the weight increase vs moving to I to them. Glad they listened!
BMAN 11-11-2014 11:30 AM
Originally Posted by Ryan (Post 500309)
Switching power off and on resets it.
Understood and makes sense if you have a locked up ABS. But that would seem to be different problem than ice mode. Reboot and you still have ice mode with stock unit.
Just disconnect it behind heater controls.
I've done it. More surprised they stated PASM which hints that the decision here didn't come with a lot of forethought. :bang: And most yaw disconnects seem to be grounded, one wire, rather than pulling the unit.
ausgeflippt951 11-11-2014 12:34 PM
That's great to hear then. 75 lbs ain't much!
TurboPooch 11-11-2014 03:22 PM
Originally Posted by Fumes (Post 500307)
all the changes
Did PCA send this out in an email? I never got it but I recently changed my email with PCA but not sure if the club racing side of PCA pulled it over.
TurboPooch 11-11-2014 03:38 PM
Originally Posted by BMAN (Post 500277)
Ice Mode. All cars not in the GTC class with ABS systems are allowed to install one or more modifications:
a) A reset switch may be installed. Anyone know more about this?
Although my racecar is a much simpler 3 channel abs, I installed a larger roll cage mounted warning light and reset switch after experiencing a couple of abs failures and the resulting spins that followed due to the severe imbalance of the brake system. What happens with my old heap for example is that hitting the rumbles coming out of T10 can cause a wheel speed variation or a flex of the spindle which will cause the sensor not to transmit pulses properly and the computer just doesn't know what to do. It shuts down and turns the small light on in the dash. Hard to see that little bugger going down the front straight and as soon as I hit the brakes around it will come. Now I can see the warning light coming out of the turn, push the momentary reset switch which cuts power to the system, and back in business in 2 seconds. This is effectively the same as shutting the car off and allowing the system to reset. If I push the reset and the light stays on, I have a component failure and know to take it easy in T1 and come in.
deutschkar 11-11-2014 05:01 PM
Originally Posted by SilverStreak (Post 500243)
In the grand scheme of things there are a lot of things that werent standard but could be optioned that are allowed in the stock classes and even some unavailable mods such as LSD in cars like the Boxster in E and F. 15 inch wheels on E 911s that effectively circumvent the not allowed ring and pinion change. Stuff like that. Sometimes I just dont get the rules committees reasoning or
Why are you suddenly hating on D, E? No reason to throw us under the bus. Freshen up your motor and you'll be fine. :idea:
SilverStreak 11-11-2014 05:18 PM
Oh man I HATE D cars!!!!
Not really. I'm just pointing out the arbitrary nature of the "if you could order it" schtick. It has a lot of holes and if I spent the money to acquire, paint and install a new deck lid with a taco wing I'd be really pissed. Particularly having to rebuild the stock wing I took off and probably do not have anymore.
Not really surprised though. Getting sort of used to PCA's rules process.
Vicegrip 11-11-2014 05:22 PM
Can you install a 1 second delay on a momentary relay and have the light reset the system?
Dr K 11-11-2014 05:52 PM
Originally Posted by Ryan (Post 500225)
I only own SP. Why wouldnt it stand? Time was set compliant to all rules
I was hoping it would stand, just not sure what crazy PCA rules were about this. And...I was told you were setting track records at every track you drove. Sorry if this was misinformation, but I must say you are damn fast in that car and a pleasure to watch. On that note: at SP CR in 2013, when I blew my engine, I got to watch most of the races rather than be driving or preparing all day. It was really, really fun, and a few of the Dorkis were especially fun to watch, on that day especially including David Dean who had exciting challenges.
Simple. Effective.
Here's a suggestion for you guys:
http://www.wdcr-scca.org/LinkClick.a...bid=73&mid=535
TurboPooch 11-11-2014 06:53 PM
Interesting idea.....I like the idea of automatic reset but would have to install a toggle switch to disable the relay in the event of a permanent failure so the thing would not be continually trying to reset until you would get off track. I guess my human relay works ok. Doesn't happen that often, maybe once or twice a year. The in the field of view yellow indicator light was the biggest help in knowing there was an issue so braking can be less aggressive and managed.
