My main question is: if I am measuring 29.5 plus sill of 1.6 what should I set this bar too. Not 18.1???????. ARF |
Your overthinking this. Raise the car on the lift , you already disconnected the SP and shock/bolt, remove the 24mm t-bar and Install the 28mm t-bar and go with 24 degrees as read on the indicator sitting on the top of the spring plate (see my pic on pg 1) thats it for Euro ride height. Now if it's too high you have around 1/2 " adjustment from the eccentric bolt on the SP to fine tune if you set in in the middle adjustment. Like I said, I went with 23 degrees and that is as low as I'm comfortable with and no rubbing. Tim |
Trial and error time. I am going to go with 20 degrees. See what happens.
ARF |
My slightly lightened race car with 33 mm T-bars reads 15-16 degrees for "race height" and 17-18 degrees for "Euro height". What a difference a thick bar makes. Will be starting that process tonight, so thanks all for posting this.
John use the calculator. Add or subtract the sill angle from the spring plate angle.
| All times are GMT -4. The time now is 10:14 AM. |
