Sorry to see that Eric. Spooky to say the least, could be that cylinder was dropped at some point in it's life or maybe the casting had a flaw. That burn through is unusual, where you running race gas?
Castings can have flaws. They crack due to thermal cycles. Happens to all other aluminum & iron heads all the time. Even if rare in the porsche world they aren't immune so I wouldn't beat yourself up over figuring why. Replace it, check everything else out, reassemble and be on your merry way.
Cool pics though :) |
Hey Eric- what a shame. What did Steve W think? Coincidentally I was emailing him while you were on the phone with him the other night.
As per my email, I would send the 6 injectors out to have them checked. Especially if 2 other heads are showing cracks as well. I'd want to know if any of them were not flowing properly and causing a lean condition. Short of a pure mechanical failure, that would seem to be the most logical cause, though that cylinder isn't pure white like a lead condition might indicate unless oil was getting in there right before it broke. Someone mentioned rodents nesting in these engines? I just completed the teardown of my recently acquired 3.6 last night and there was a big nest on top of #6, with all sorts of crap jammed down into all the fins of that barrel. Most certainly would have caused serious overheating problems on that cylinder if I hadn't torn it down. So you going to have Steve W do the same valves and cams he's doing for me? |
Steve's opinion is that while bad casting/metal fatigue/improper torquing can occur, heads most often crack because they been overheated, and they nearly always get too hot because they ran too lean (pre-ignition, detonation, crack). Possible suspects not yet ruled out include insufficient fuel caused by a bad injector or faulty management system or an air leak. All injectors are being cleaned and flow-matched. Point of clarification - the other two heads are not cracked at all; however, when the first head cracked the fitment between the heads and cylinders was compromised only enough that you could see that small tell-tale carbon indicating some exhaust gases had leaked between them. There doesn’t appear to be any damage to those heads, but one consideration is to replace them as well. Visible evidence of the metal surfaces shows that the other cylinders are all burning perfectly; rather than the signs you would expect to see with a lean condition cylinder #1 is actually showing the blacker after-effects of the crack. It is possible that the lean condition happened in the past and the consequence manifesting now. Glad you found the nest in your new/old engine! It certainly happens, but wasn’t the case in my failure. I’ve thought about valves and cams, but want to continue with it in stock form. I’m basically doing rings, valves and head studs for a fresh to end, adding some reliability bits and replacing most of the rubber in the intake system. It's plenty capable as it is and doing it right means that I'll be happy with it for a long time...me or someone else should a 997 GT3 ever make it's way into my garage! |
Heads will be on their way to Steve tomorrow. I'll split the case in a week or so and get the rod on their way shortly thereafter. Good to hear the other heads aren't cracked. I may have read between the lines based on your email a few days ago. So just one head and a fresh top-end to be good for another 15K miles? Good to hear. But why limit your sights to a GT3, go for a GT3RS or a Cup Car. It's only money. |
Sorry to see, but maybe this is that sign your were looking for to make a change in cars? Good deals on tracked prepped GT3s out there this winter!
And for the good news: I picked the car up from ASG last week and put some break-in miles on it over the weekend. Had the oil changed this week and everything checked out, so the RSA is back in business! Funny how not driving your car for four months makes it seem like it runs great. But it sure runs GREAT! Now if I can just break away from work...Hello, VIR!!! |
Congrats on getting it running again. Enjoy.
| All times are GMT -4. The time now is 09:18 PM. |
