-   -   What's the safest way to look for vacuum leaks? (https://dorkiphus.net/porsche/showthread.php?t=14965)
Patrick3000 09-19-2007 05:58 PM
John,
How would you go about making one with a shop vac and dry ice? I'm still trying to find the leak in the 912E.
Regards,
BlackTalon 09-24-2007 04:39 PM
Originally Posted by Rick Lee (Post 156198)
It taking my intake off were that simple, I'd do it too. Pulling my engine requires an alignment afterwards. I'm probably headed for a smoke test and injector cleaning.
I think IMA has a smoke machine. If you're going to use them to clean the injectors, maybe you can also see about getting some 'smoke time'
Rick Lee 09-24-2007 05:03 PM
Speaking of IMA, I called a few times last week and there was no answer or vm. I email Ivan and no response.
turbo23dog 09-25-2007 12:25 PM
I just had my 80SC smoke tested at RPM in Newington in diagnosing a lean condition. They found that the large rubber boot on the back side of the CIS equipment had a huge crack in it right where one of the two hose clamps holds the boot to the intake. We'd have never found this without the smoke. They used chemicals all over the metal to metal mating surfaces and found nothing. It was the smoke machine that found the problem.
BlackTalon 09-25-2007 05:16 PM
Hmmm, maybe they are finally completing the move to the new shop
