-   -   2001 Boxster S Engine (M96/21) Rebuild (https://dorkiphus.net/porsche/showthread.php?t=33667)
N0tt0N 01-12-2015 05:02 PM
And you primed the chain tensioners
smdubovsky 01-12-2015 05:34 PM
Fluid will take path of least resistance. It will displace almost all the air, filling all the tubes, and then suddenly develop oil pressure everywhere at the same time. You can't develop multiple bar of pressure at the mains while there is still an empty passages/tubes going out to the heads. If you used assembly lube it should be fine while you crank (w/o fuel pump fuse as you mentioned.)
Rob VN 01-12-2015 07:22 PM
Mihnea,
+1 on cranking with the fuel pump fuse pulled.
Rob
987kmns 01-13-2015 12:50 AM
Yep.
And a little more progress today. Transmission is in and motor and trans are back on their mounts. It won't be long now.
http://i983.photobucket.com/albums/a...psiqia9usr.jpg
http://i983.photobucket.com/albums/a...psprp6jfps.jpg
ausgeflippt951 01-13-2015 09:44 AM
Hot damn! Able to fire it up tonight?
987kmns 01-13-2015 09:52 AM
No, sadly the next time I'll be able to work on it is Thursday, so hopefully then.
987kmns 01-13-2015 11:13 PM
Since I didn't get a chance to work on the car today, I don't have any updates. Here are a couple photos I edited on my phone. I was just playing around with some psychedelic colors.
First, the valve tappet housing, which is a beautifully made piece and also incredibly light to hold.
http://i983.photobucket.com/albums/a...psh2qpsncp.jpg
And then the tappets installed in the head.
http://i983.photobucket.com/albums/a...pskmhb5txf.jpg
987kmns 01-16-2015 04:12 AM
Well, it started and it runs well. Off to bed. More details tomorrow.
roundel 01-16-2015 08:05 AM
Congratulations!
N0tt0N 01-16-2015 08:34 AM
Woot! Way to go, man! Congratulations to you and Ion. Very impressive.
