it broke
I know there is a p-car device for tensioning ... however, when I used to change belts on volvos ... you'd have to get under there while the motor was running and tension the idler "just enough" so that the balance shaft [I think] wouldn't howl / groan. I am assuming you can't do the same with '44s b/c to many pieces are off the motor to let it run? One of the dorki [you?] must have the '44 porsche tensioner tool ... Jase |
That buh-lows. You're still in for VIR, no?
Thanks Jase. I got a "cricket" from Rennbay. Worked great. The belt did not look old to me. This leaves several possibilities . . . defective belt, defective installation, or new old stock belt that was dry rotted.
Chris: I'm still in . . . motor is back together, just waiting for the injectors to be returned from the injector place. It'll be at tech on Sat. Marc |
I saw this on another board on Thursday.
Scared me into stopping by ASG on my way home this past Friday and asked for an estimate to replace my 40K Km (I think) belt. Sorry to hear about the bad luck, glad to see you are almost back on the road. |
DIY in true Marc A./ Dave R. Dorki style ...unless you are turning into one of those new 99X REWC types ... :twisted: :lol: Jase |
Glad to hear the bottom end wasn't affected. Happened to me with a bad tensioner on my 124 spyder and the pistons needed help (difference between a FIAT and a Porsche?). Hope the weather hold out for ya.
Does anyone find it just a little suspect that Marc found a reason to pull this engine apart within a week of owning the car???
Truly ugly luck that the belt failed after little more than a year. Something wrong with that picture - either tensioning or a faulty belt. Makes me want to go check mine [installed January last] every time I run the car! Good news is that Marc is now a FEWC god, and that his bores and pistons were in perfect shape. If you have half the fun that Todd is having with his 944 Marc, it will all be worth it. |
| All times are GMT -4. The time now is 10:53 PM. |
