-   Tools Needed/For Loan (https://dorkiphus.net/porsche/forumdisplay.php?f=55)
-   -   600 lb/ft torque wrench (https://dorkiphus.net/porsche/showthread.php?t=4319)
BlackTalon 12-15-2004 08:37 PM
Originally Posted by david riley
Dave, I’m the same guy, you just listen closer. Especially after I saved your a## from being compressed, and as always thanks for the uncivil engineering and math lessons :!:
And Paul you are welcome to the wrench when ever you need it
Ah, It's a Wonderful Life!! 8)
William Miller 01-10-2005 01:42 PM
Anyone comming to Old Tee's Saturday? I'd like to barrow the big torque wrench for a few minutes for my rear axle nuts and Ball joints.
I have the sockets but I think their 1/2" drive. So do I need an adapter?
Thanks!
APKhaos 01-10-2005 01:58 PM
Originally Posted by Paul 951
I did my rear wheel bearings recently and don't have a wrench capable of setting the axle nuts to the required torque (360 ft/lbs I beleive). Is there any chance I can borrow this tool? I understand I'm a new guy so you may be wary...
Let me know, and thanks in advance!
Dave, John,
I have met Paul, and helped him out with his external oil filter install. He has done a nice job on his engine - solo in his garage, Dorki style.
Seems like one of us, and did a ton of diligent research before starting his engine work. I'd let him use any of my tools.
Paul 951 04-21-2005 02:28 PM
Wow Tony, Thanks! I don't know how I missed this post, I could have used the confidence boost around mid-January.
I think your words might be too kind though, since I can't for the life of me get my car running!
Or maybe that is the Dorki style you were eluding to? ;-)
Thanks again Tony...speaking of - can I borrow your coolant system pressure tester? ;-)
Paul
PS: By the way, I do beleive I ended up indirectly borrowing your torque wrench David, through Eric D...So, Many thanks! It worked a treat! And if I had it for longer than you expected, it was Eric's fault, I swear. ;-) Now I'm in trouble....
