Continue here with some cleaning.
Did I mention that this car was a mess ? http://airboxer.com/944/2018-02-10-2.jpg Cleaning time. http://airboxer.com/944/2018-02-10-1.jpg http://airboxer.com/944/2018-02-12-1.jpg Front support cleaned up. http://airboxer.com/944/2018-02-12-2.jpg http://airboxer.com/944/2018-02-12-3.jpg Cleaned and plated some hardware. http://airboxer.com/944/2018-02-14.jpg So now I got this 944 Turbo transmission at the right. The left one which came out of the 944 has a longer 5th gear. So I will swap them out. http://airboxer.com/944/2018-02-16-1.jpg To be continued. Cheers Engelbert |
Did a little work on the brakes.
http://airboxer.com/944/2018-02-07-01.jpg The calipers looked pretty ugly. http://airboxer.com/944/2018-02-07-02.jpg I took them apart and cleaned it all up. http://airboxer.com/944/2018-02-07-03.jpg Here are they ready for assembly. http://airboxer.com/944/2018-02-23-1.jpg Assembled and ready to go in. http://airboxer.com/944/2018-02-23-2.jpg Rear end done. http://airboxer.com/944/2018-02-23-3.jpg Front end also in. The sway bar is not yet installed, and I wait with that for better access. http://airboxer.com/944/2018-02-23-4.jpg Cheers Engelbert |
I'm going to assume you clocked the pistons in the calipers to the proper 20 degree angle?
Good Point, yes, I did.
Thanks for asking. Cheers Engelbert |
I made some progress with my Hybrid project
http://airboxer.com/944/2018-02-21-01.jpg Got the power plant ready to go in to test fit. http://airboxer.com/944/2018-02-21-02.jpg Coming down. http://airboxer.com/944/2018-02-21-03.jpg Looks like it's gonna fit. http://airboxer.com/944/2018-02-21-04.jpg It looks like it belongs there. http://airboxer.com/944/2018-02-21-05.jpg There is more space around than I expected. Wow. A lot more work to do. http://airboxer.com/944/2018-02-21-06.jpg Cheers Engelbert |
This all seems very familiar...
What are you going to use for a brake booster? I had an ABS electric brake booster and it was the only thing I didn’t like about the swap. I feel like it was underboosting and the brakes felt wooden with no bite, and the pedal had no modulation. |
Nice!
Amazing how relatively small a smallblock OHV engine is. Would be tempted to make one fit in my S6 if it ever breaks (fingers crossed it doesn't) |
bad ass.
| All times are GMT -4. The time now is 09:34 AM. |
