-   -   Washing machine installation help (https://dorkiphus.net/porsche/showthread.php?t=32498)
Dave O 05-17-2014 07:00 PM
How can the drain immediately go downward from that opening if that electrical box is below it??? Something doesn't seem right.
APKhaos 05-17-2014 11:34 PM
Must say that 'drain' looks the right size and placement for a dryer vent.
Dr K 05-18-2014 12:02 PM
Agree. Is the ground right outside that vent cover on the side of your house wet?
Robert in Potomac 05-18-2014 05:22 PM
It is very strange, but it has worked for over 20 years. Drain hole curves down and to the left almost immediately. I am guessing that the drain or outlet was installed after the house was built, it makes no sense. But, I thank you for pointing it out to me, I am not using that outlet and will have it covered. Solved problem of flexible hose by purchasing a short flexible hose to attached to wash drain hose, so I think all is well - at least i hope so.
