-   -   Home alignment (https://dorkiphus.net/porsche/showthread.php?t=3239)
Charlie Stylianos 04-17-2003 10:54 AM
I'm glad you guys are testing the procedures. Aslo glad Jim, they they wern't too hard to follow.
After a total front and rear suspension teardown/rebuild, everything will be out of wack.
RoninLB 04-17-2003 11:03 AM
I confirm the alignment that I want with a temp gauge placed between the threads.. and remove my hands from the wheel..
I do a straight/level fast ride for a few miles to warm them up, and then pull over and check the front or rear pair very quickly in left/center/right.. then a re-check. they cool very quickly. I align with 3/4 tank of gas, so that's what I check tire temps.. there is more info around on track tire temps, but I don't have it.. to my understanding many track guys do tire temps..
and I did a quick 18k miles a short time ago, and everything was fine.. based on the tire wear of brand new tires.. of course correct tire psi before doing this temp act is important...............Ron
Jim Richards 04-17-2003 11:07 AM
:lol:
Charlie Stylianos 04-17-2003 11:21 AM
I found this handy tool at the Home Depot. 360 degree protractor for $9.
- Transfers angles to within 1 degree
- Easy reading dial with adjustable angle pointer
Excellent for setting spring plate angle when indexing t-bars for ride height.
Also, with a 2x4 against the tire and the guage against the 2x4, reading the correct camber is probably easier than using the level or plub bob method.
http://www.homedepot.com/cmc_upload/...9/A19717_3.JPG
RoninLB 04-17-2003 04:22 PM
that tool is great..
also to set rake.. I lay in on the lower door opening / tub.........Ron
targa911man 04-18-2003 11:31 AM
[quote="Charlie Stylianos"]
Charlie--
Won't the bulge at the bottom of the tire throw off the camber angle reading with that method? The booklet emphasizes taking the reading off the top and bottom of the rim, not the tire, I think for that reason.
Charlie Stylianos 04-18-2003 11:51 AM
Dan,
Good point.....
For some reason I was thinking 'rear wheels off the ground'. Maybe because that's been my view the last 3 months. :? The camber reading should be taken with the rear fully loaded.
Cut 2x4 to fit the wheel, not touching the tire :wink:
Jim Richards 04-18-2003 12:00 PM
That's the ticket. But when you're in there making the camber change, you'll have the car up on jackstands and the rear wheels off. The angle they droop to when unloaded now changes. So, you make changes to that angle to achieve the desired camber, tighten everything back up, put the wheels back on, lower the car back down, and then verify your new camber setting.
APKhaos 04-18-2003 08:43 PM
Its critical to roll the car a length or so after lowering back onto the tires. The geometry of the rear suspension puts the outside edges on the ground first at an extreme camber angle. As the car comes down, tire friction prevents the wheels from reaching their natural camber position. Need to rollit to let things settle, then measure.
My daughter would say "Thank you, Captain Obvious!" so you can too if you already do all this.
Jim Richards 04-18-2003 09:11 PM
I think I should be called Capt. Oblivious, as I didn't think about this. :roll:
Thanks for the pointer, Tony!
