what do you think ive been doing......
priceless post though. |
LOL Just think, with the new headers and HP you'll now only be 24 seconds behind the leaders(Evan) instead of 27 seconds:shock: |
I'm 50/50. Work is beyond insane right now. If I go I'll be leaving at midnight on Thursday and won't be worth a crap on Friday. We'll see....
Btw, I have Scargo headers but they were "only" around $1,200. They sell cheaper non-US made versions now.....which I was told by them will run about 5-10 less rwhp than the hand made ones. :roll: |
Packed up the car, truck, and trailer last night. Still need to change brake pads but I should have time to do that Thursday after I arrive. Too busy at work to knock that out before tomorrow.
Ya'll be safe down there! :D
Would rather not be reading any more "rollover" and "money shift threads". |
I'd be happy to be only 27 seconds behind Evan at the end of the race. That's only 1-1/2 seconds/lap slower than he is. Unfortunately, I'm slower than that. And just as unfortunately, Frank is too! :twisted:
See you guys Saturday drive safe tomorrow
Well, I'm home! My car continued to have the "miss" in the 5000-6000 RPM range, actually worsening since Watkins Glen. Have found lots of small things, but none has fixed this problem (not all these problems were found by me):
Old wires (replaced) Old rotor and cap (replaced) Spark plugs replaced just for completeness Leak in fuel pressure regulator (leaking fuel into vacuum line) (replaced) 2 injectors leaking fuel, not working correctly (all injectors replaced with new) Fuel filter replaced. At track: data logger disconnected (no help) questionable wiring on 4-pin connector DME harness to engine (re-soldered, twice) coil? Ran with known good from Intersport (no help) engine temperature sensor connector not as tight as we'd like - zip-tied together (no help) I went out 4 times. Got 1 lap at speed the first time, but the miss came up in the first lap each other time and I came in. It actually got worse the 3rd time (known good coil and re-soldering the connector the first time). Put my coil back in and resoldered the connector again, and it was back to more typical (got almost a lap before the miss started). Interestingly, while it's hard to accelerate with this, if I can get the revs up to about 6000, it will get better for [initially a minute, but at VIR only 20 seconds or less before the miss starts again]. Any suggestions appreciated. I've been told my DME is fine (I thought of that, and will likely try a loaner if we can't find another solution). |
| All times are GMT -4. The time now is 05:37 PM. |
