-   -   My 914 Project thread... (https://dorkiphus.net/porsche/showthread.php?t=20676)
Casey914 09-05-2009 10:50 AM
The speedo drive came out of the back.
DSgraham 09-05-2009 11:36 AM
:-O
My '74 never did that... I'll have to call the old man, he had a Tangerine '72 1.7.
Was it a failure so to speak, or a failure to tighten something?
Casey914 09-05-2009 01:50 PM
i have no idea... My guess is that it was the first time car car had really run through the gears and gotten up to a sustained higher speed in 10 year. Due to that it just worked out. Keep in mind it has a rebuilt side shift(not original to the car) so it could have just been worked out during the process.
type954 09-06-2009 11:17 AM
Speedo drive is held in by a "set screw" (an 8mm bolt if I recall, maybe even cone tip). Look for a threaded hole in the area of the drive. Maybe the screw vibrated out in the glee of being back on the road or something.
Casey914 09-12-2009 10:47 AM
Thanks Jim... I have all of the parts assembled to put the thing back together... hopefully some time this week.
Casey
Casey914 10-17-2009 09:14 AM
Car has been running well. Drove it in teh rain and 40 degree temp w/ no heat or defrost this morning. i am hating life right now, but the car ran great!
type954 10-17-2009 06:21 PM
Wow! If it rains, I drive my Vanagon that has no heat or wipers.
markwemple 10-17-2009 06:30 PM
You don't have HEs?
Casey914 10-19-2009 11:14 AM
no, wasnt in the budget :) got a set of 1.7s around you dont need?
markwemple 10-19-2009 12:03 PM
You can install 2.0s. Those are still available. Mine went with my 914 but you should be able to find 2.0a on e-bay. You will also need the muffler as the assembly was different. It will also give you a minor bhp bump but on a 1.7 any bump is welcome.
