-   -   Cayman S (987.1) HPDE Season Prep (https://dorkiphus.net/porsche/showthread.php?t=33960)
Rob VN 03-07-2015 08:26 AM
Mihnea,
+1 on the air scoop which I used, then converted to electric. After getting 0 nibbles on my Cayman I am giving it to my son so he can enjoy the mods and we can work on it together. He is already in contact with Flat Six about their 2.7 to 3.5 engine conversion.....
Thanks for the tip on the Redline CV grease.
Rob
N0tt0N 03-07-2015 11:25 AM
That's a great pic. Looks like a launch tube!
987kmns 03-08-2015 10:24 PM
Ha ha, it sure does. It certainly feels like a launch tube when you're trying to work around the car.
Today Ion and I got the car aligned. A big thanks to Vranko for stopping by yesterday to help inspect the car for Zone 2!
SmartStrings system being set up.
http://i983.photobucket.com/albums/a...psqw49319u.jpg
http://i983.photobucket.com/albums/a...psk6ab3jkx.jpghttp://i983.photobucket.com/albums/a...pslwlszek7.jpg
http://i983.photobucket.com/albums/a...psuj3m5ylw.jpg
Definitely on the home stretch now. Starting to get excited about the rainy weekend ahead!
vranko 03-09-2015 11:55 AM
^ Thanks for sharing your alignment technique. If was great hanging out with you and your brother. Can't wait to do mine sometime.
Having the all season tires put back on the Golf R today! Can't wait. :shock:
Intubator 03-09-2015 02:13 PM
Any chance you guys might bring that string setup to VIR? I just replaced my rear toe links and would like to double check the toe before hitting the (wet) tarmack Friday....
987kmns 03-09-2015 02:17 PM
I can bring everything but the ramps, which take up a lot of space. The rest of the setup disassembles well.
Vicegrip 03-09-2015 02:52 PM
Is the car level when you take measurements?
987kmns 03-09-2015 03:20 PM
Camber yes - it must be. Toe no. I have the axle that I am currently working on, on ramps. I did measure toe both level and with one axle elevated and found no noticeable difference with my measurement tools. No argument that having the car level at all times is the most accurate way. I will work on that once I own a garage...
Intubator 03-09-2015 08:04 PM
Thanks! I'll give it a try without ramps as I just have to check the toe setting. I have an 06 Cayman S in guards red with black wheels as well so I'm sure we"ll spot each other. I'll PM you as well.
987kmns 03-10-2015 01:05 AM
PMed you back.
