Replacing Flywheel Sensors on an Intact Car (engine in)
NOTE: Thanks to Matt De Maria for explaining how to do this.
The "upper" sensor is the "reference" sensor, which tells the DME when top dead center (TDC) passes during cranking (there is a set screw in the flywheel). The "lower" sensor is the speed sensor responding to a toothed wheel on the flywheel. Two voltage pulses are generated for each tooth on the flywheel (Bentley manual, page 200-5 and 280-11) Tools needed: Jack Jack Stand Lug Wrench (or similar, to remove wheel lugs) 5 mm. long ball-headed Allen wrench (or short socket-type with extension and ratchet handle) 8 mm socket (if you need to remove plastic tube from heater fan to get to connectors) 10 and 13 mm sockets (and ratchet handle) Silicone spray Torque wrench with low range (8 ft-lbs) Flat-headed screw driver String (silver Sharpie)
*If the sensor screw is seized in the mounting bracket, you might need to remove the mounting bracket and get the sensors off away from the car. I'm not sure this can be done with the engine in the car, but I believe it can. When I did this job, my screws came out very easily so no need to touch the bracket. If you remove the bracket, you'll need to re-gap the sensors when you replace the bracket, but if you don't remove or loosen the bracket, the new sensors should have the correct gap when installed. Peter
Peter (not "Pete") K. 2016 Cayman S 1999 Miata ("SM") race car 2016 Toyota Highlander--tow vehicle/wife's DD 2017 VW GTI SE (DD) Gone and missed: 1992 Miata ("SSM") race car 2009 911 C2S Coupe 2004 Toyota Prius - sold to son's girlfriend 2006 Dodge Durango 2003 Acura MDX 86 Black 911 Coupe race car 86 Gold 911 Targa 82 WineRedMetallic 911 Targa Last edited by Dr K; 09-22-2013 at 12:48 AM. |
Above instructions updated (we did this again today). Also, here are some photos:
Here are the old connectors in place (step 7) Ball-headed Allen used to remove sensors (step 9) Gasket bent so wire can be removed (or inserted) (step 12, step 23) Separating 2 pieces of connector bracket (to unlock connectors) (step 13) Sensor plug ends in engine compartments (note string) (step 14) Sensors will be inserted here, but bracket is dirty (step 17) Bracket after cleaning (step 17) Sensors in place step 21 Note gasket back in fire wall Connectors attached (don't forget the locking plate) (step 22) Cable clamp with wires in place (this one is in wheel well, there is another in the engine compartment) (step 24)
Peter (not "Pete") K. 2016 Cayman S 1999 Miata ("SM") race car 2016 Toyota Highlander--tow vehicle/wife's DD 2017 VW GTI SE (DD) Gone and missed: 1992 Miata ("SSM") race car 2009 911 C2S Coupe 2004 Toyota Prius - sold to son's girlfriend 2006 Dodge Durango 2003 Acura MDX 86 Black 911 Coupe race car 86 Gold 911 Targa 82 WineRedMetallic 911 Targa Last edited by Dr K; 09-22-2013 at 12:50 AM. |
Clear and to the point --
Much appreciated picture taking of the fine install details --
