Complete data logger geek-out
One of my "winter" projects is to wire the car for logging using the RacePak G2X I've had for a couple years. Its been used in the past for standard GPS/speed/RPM data. Time for more data if for no other reason than (1) I'm a geek and (2) it's job related.
Hire me so I can do the same and write this stuff off, too
just buy the setup add a bracket or two, sell them at a lose (making it up in volume like the car dealerships) and there you are
Sensor-mania
Greg,
Is this for your 964? If so, please let me know how/where you insert the brake pressure sensor. That is a data point I would like to collect. I would also be interested in where/how you pick up the TPS. Thanks!
Previous: 2010 911 GT3 1993 911 RS America 1992 911 C2 Targa |
I know my 944 will be different, but I'm sure I can adapt other's ideas. Thanks. Jim
Jim 1986 Porsche 944 Turbo |
http://www.pegasusautoracing.com/pro...p?Product=3209 http://www.pegasusautoracing.com/pro....asp?RecId=906 The plan is to plumb it into the left rear brake line, preferably in position A. Part #42 is being replaced with a new stainless flexible brake line. Part #41 was replaced with stainless awhile ago. The guess is the female ends are 3AN, otherwise I'm still looking. Quote:
Greg DuPertuis When in doubt, always mount a scratch monkey. Leesburg, VA Last edited by rs911t; 03-25-2008 at 11:00 PM. |
Sold the 964, down to a single Porsche. It's all going into the '72T. That said, a variation on my plan should work with the 964. I'll post more pix when I have the parts and the bits installed.
I'm now in the process of installing the Racepak IQ3 in my 1986 951
The interesting part of this job for me is the ability to tap in to various wires for the DME and KLR without buying or installing new sensors. I've tapped into the throttle position pickup and the DME eng. temp sensor.
Last night, I spent about 2 hours with the temperature sensor in a can of water, and gradually brought the water to a boil in order to generate a volt versus temperature curve that I entered into the IQ3. My next sensor is boost. While there is a boost output to the dash, I'm not optomistic about tapping into this, as there are two wires for the boost gauge (not one), and the voltage of that one varried between 7 and 8 volts. The input for the Racepak system has a max of 5 volts. Thus far, I'm disapointed with the support of Racepak on their IQ3. I'm having problems keeping the accelerometers in calibration. Also, the manual does not explain some of the features such as setting the start/finish line and reviewing lap times via the IQ3. I've asked at least 3 maybe 4 times for assistance, but have not gotten the necessary information. I'm guessing that there are bugs in the firmware, and they can't fix the problems without a firmware update which is not ready yet. They promised a corrected instruction manual 2 weeks ago, but it has not been released yet. More to follow when things are fully installed. Here's a picture of my setup.
Do you have the cable to the Universal Sensor Module backwards? I thought the double ended connector goes to the VNET bus (e.g., the wirewall or your fuel pump voltage sensor), and the single connector terminates at the USM? Maybe it works both ways?
On my G2X I have brake pressure, and throttle position sensors. For the brake pressure I used an autometer adapter to go from the 1/8NPT to the metric fittings on my master cylinder. The master cylinder in my car has 4 outputs, 2 for each circuit. So I just removed one of the plugs, and used that as a tap point. Best price on the adapter at the time was from amazon, of all places.
Todd
