Anyone know what would cause the ECU to drop injector pulses?(924S)
Donnie 1974 911-sold 1995 BMW M3-GTS2 2001 Excursion diesel tow beast |
Have you read through Jazz's explanation and tech stuff on the "brain?" Lots of good info and most is good for '24s/'44s.
Bad injector transistor. Bad solder joints in the DME. Open the DME and look around see if you see anything obvious. Check out FRWilks site in the Motronic section - 944 DME specific stuff.
